die technischen Daten:
www.marutigypsy.com hat geschrieben:Dimensions
Length 4010 mm
Width 1540 mm
Height 1875/1845 mm*
Wheelbase 2375
Front Track 1300 mm
Rear Track 1310 mm
Kerb Weight 985 kg/1,050kg*
Gross Vehicle Weight 1585kg/1,650kg*
Width 1540 mm
Engine
Type G13BB MPFI 16 Valve Gasoline
Cylinder 4
Displacement 1298cc
Maximum Power 80 bhp @6000 rpm
Maximum Torque 103 Nm @ 4500 rpm
Transmission
Type Five forward (all Synchromesh), One reverse
Transfer gearbox Two-speed
Type constant mesh
Transfer gear ratio High : 1.409; Low : 2.268
Suspension
Front and Rear Rear Leaf spring with Double action damper
Brakes With Booster
Front Disc
Rear Drum
Tyres
Type F78-15-4 PR 205/70R15
Capacities
Fuel tank 40 L
Engine oil 4.0 L
Ausstattung:
Electrical Equipment
Windshield washer and two-speed wiper
Hazard warning light
Hydraulic clutch in cooling fan
Distributor-less ignition
Multi-function levers
Interior Equipment
Fabric upholstery in hard top
Vanity mirror on left sunvisor
Reclining and sliding front seats
Adjustable head restraints
Front package tray
Lockable glove compartment
Floor carpet
Steering lock
Front seat walk-in assembly (co-driver)
Exterior Equipment
Driver's side rear view mirror
Spare wheel cover
Front footstep assembly*
Foldable Front windscreen**
Fibre Reinforced Plastic*/ Removable canvas top**
* Hard Top Variant ** Soft Top Variant
Grüße
Peter
