Enkei felgen - need help
Beitragvon lazare » Mo, 17 Okt 2011, 13:00
Hello everybody! I'm Roman from Ukraine! Just bought a set of such wheels: Enkei Apache 8,5x15 ET -20. Does it fit to my stock SJ413? What size of the tyres is the best choice for this wheels: 235 or wider? Thank you!
lazare
Beitragvon sebbo » Mo, 17 Okt 2011, 13:39
do you want to put mud terrain tires on it or just street tires?
mud terrain the smallest size will be a 30 9.5 15 tire
street tire ~255/60 15
havent found a 235 tire thats allowed to be mounted on 8,5 inch rim
sebbo
Beitragvon lazare » Mo, 17 Okt 2011, 14:27
sebbo hat geschrieben:do you want to put mud terrain tires on it or just street tires?
Thank's. Do I need to do any lift or it will be ok with 255 on the stock car.
thinking about this BFGoodrich ALL-TERRAIN T/A KO 30"/9.5 R15 104S
Here is my Samurai
lazare
Beitragvon sebbo » Mo, 17 Okt 2011, 14:39
i dont think you will ned to lift it.
depending on on the laws in your country you may have to widen your fender flares
sebbo
Zurück zu Reifen und Felgen
