Just found your website/BBS, thought this might be of interest to your members...........
SOS (SuzukiiOnlySupply) 16LTOY@msn.com
The “RingR”™ -SUZUKI ENGINE - TOYOTA TRANSMISSION ADAPTER
Just letting Suzuki enthusiasts know about a new part we have available. It’s the “RingR”™, a billet aluminum adapter that bolts in-between the Suzuki 1.6 liter 4x4 bell housing and Toyota 4 & 6 cylinder manual transmissions (Turbo included).
Precision machined from solid billet 6061-T651 aircraft quality aluminum, and supplied with Grade 5+ hardware, the “RingR”™ setup affords much greater strength and durability to your driveline, as well as numerous gearing options to get that KILLER CRAWL RATIO you desire!!
The “RingR”™ gives you the advantage of a stronger transmission and t-case(s), along with the ability to increase crawl ratios to a mind boggling 555 to 1 if one was so inclined (insane!). Slight modifications are needed for the clutch and throw out bearing, optional for the pilot bearing, but these two parts along with the pilot bearing of choice can be bought off the shelf anywhere in the world. If one chooses, these modified parts can be included with the “RingR”™ at an additional charge. 4 cyl. Transmission Adapter Part# S2T4 $399 USD; 6cyl. Adapter Part# S2T6 $499 USD.
We can even put together a complete “turn-key” package for you, including transmission, transfer case (single, dual, or more, with adapters via Marlin Crawler), and all parts for your installation using the “RingR”™. Just call with your needs and we will be happy to provide you with the trickest setup available-Ours!
Also available from SOS~
The “Lucky 13”™. This adapter allows you to mate the Suzuki 1.3L engine to the Suzuki 1.6L 4x4 bell housing -more possibilities!!! Best of all, the price;
$49 U.S.!!!
If you or anyone would like more info, photos, pricing, or has questions
please feel free to contact me, Kerry Wittig, at Telephone # 607-274-SLOW
(7569) or 607-227-1244. E-Mail:16LTOY@msn.com
[/img]
